跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
116 个问题 查看全部
M1 MBP motherboard in M2 MBP chassis. Will it work?
Hi everyone.
I bought via FB Marketplace an M2 13-inch MBP and a Late 2020 M1 13-inch MBP for cheap due to liquid damage. I was able to clean the M2 MBP and make it work. I am really happy about that.
However, the M1 MBP just turns on but is not showing anything in the display. The M1 MBP will make a chime when powered on and the keyboard backlight is working. So I really don't know if the motherboard is faulty or the display is.
I would like to see if the M1 motherboard is actually working and I read here in iFixit that the display of the M2 is compatible with the M1 display.
Given this, would it work if I put the M2 motherboard in the M1 chassis? Thought of asking first before taking them apart. Thanks!
BTW. I tried doing a restore/revive via DFU on the M1 MBP but it won't proceed [The system cannot be restored on this device - 0xFCA (4042)].
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I believe there were some minor changes to the trackpad/keyboard on these. I believe it will mostly work just fine, but based on the iFixit blog from when these launched, I am skeptical the trackpad will function as expected. But otherwise these are exceptionally similar.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
PATRICK AQUINO 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 29
