跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
395 个问题 查看全部
Need help with capacitor value at F5105
Hi all, I have a PS4 PRO NVG-004 motherboard and need help with finding out what capacitor value these are.
Took out one of it and it shows that it’s short so would like to replace it! Anyone has a donor board and can test it?
Thank you so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I cannot find a schematic, but the black component to the right of the capacitors is a AON6414A MOSFET which leads me to believe the capacitors are the input to a switching voltage regulator. If you've removed this part and confirmed that it is internally shorted, there may be enough capacitance in the 3 neighboring caps to allow the device to work as-is.
If you want to be super safe, you can buy a large capacitor in the same footprint with a 30V rating or greater (not sure what voltages these actually will see), at a large capacitance like 100uF, it doesn't need to exactly match the old component. You'd have to measure the physical dimensions to get the correct capacitor package, but these devices are pretty standardized.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Justin Png 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 47
