跳转到主内容
2016年版Retina MacBook的更新版本。型号A1534,EMC 3099。现在采用更快的Kaby Lake处理器,最高可达1.4 GHz Core i7,支持Turbo Boost加速至3.6 GHz,SSD速度提升高达50%,并支持高达两倍的内存。
82 个问题 查看全部
Replacement battery no longer working
Hi, I replaced the battery in my daughters MacBook with the kit purchased from iFixit, it was working fine until recently, it now will not charge and in system report it is showing battery cycles 0 and needing attention, any assistance with this will be appreciated.
Thanks
Chris
Update (04/24/24)
Hi Dan, I replaced the battery end of Feb 2023, I have attached a screen shot of the CoconutBattery.
Thanks
Chris
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When did you replace the battery? And if you can let’s get a snapshot of CoconutBattery main window so we can see all of the batteries data with the charger plugged in posted here so we can see things too.
Update (04/24/24)
@chrismurley - Ouch! This battery is no good. The NaN errors is due to a bad Microcontroller chip within the battery.
Due to COVID chip availability was tight as some battery makers tried salvaging chips from dead batteries. The QC to check these reused chips was let’s say… not well done.
You need a new battery, you might try getting a replacement from where you bought it if they offer a warranty.
这个答案有帮助吗?
得分 1
1条评论:
I know the warranty on iFixit batteries is one year, but despite that it would be worth your time to talk to the iFixit Store personnel about your situation; I agree with Dan that it looks like the BMS (Battery Management System) on your replacement battery looks pretty dead, so there may be something they can do. Best way is to email them at support@ifixit.com.
完成的
添加一条评论
添加你的答案
Chris Murley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
