跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
206 个问题 查看全部
2018 MacBook Pro Turning on but no video
I have a 2018 15” MacBook Pro. The display doesn’t work so it’s being used with an external monitor. It suddenly stopped outputting video to the external monitor. But it does turn on (the fans spin and the caps lock key can light on). I’ve tried different monitors and cables. I’ve reset the NVRAM and SMC and tried the standard troubleshooting. There are no signs of water damage. I put it in DFU mode and did a revive and restore using Apple Configurator.
At one point it did start displaying on the monitor for a few minutes and I started booting to internet recovery mode, but then it stopped and hasn’t displayed on the monitor again.
Is there anything else I can try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try disconnecting internal screen completely. remove back plate, disable battery, disconnect screen, isolate the connector with tape and reverse process to assembly. do a 3x pram reset loop and it will output main picture to the external screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas Metaxas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 19
