跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 个问题 查看全部
Why Is the New Back Glass not Flush with the Mid-Frame and Flash?
Hello,
I have finished replacing the back glass on my Samsung Galaxy Note 5. I noticed that the back glass is not sitting flush with the mid-frame and the heart rate sensor/flash even after pressing on the back glass focusing on these areas for over a minute.
Are there any solutions to solve these gaps?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
is it genuine rear glass or chinese copy ?
这个答案有帮助吗?
得分 1
5条评论:
The back glass was bought from some seller on Ebay.
完成的
@tanveerzubair proably a chinese copy, better buying genuine
完成的
Ok. Is there at least any workaround to this?
完成的
@tanveerzubair is that frame bent ?
完成的
@tech_ni As of what I see, it is very minimal.
完成的
添加一条评论
@tanveerzubair Assuming you followed the iFixit guide for replacing the back panel, that would mean you didn't remove the midframe so you wouldn't have been able to directly examine the battery for swelling, which is what this looks like to me.
That's what I'd check next if I was working on this; a bulging battery would perfectly explain what you're seeing.
这个答案有帮助吗?
得分 1
10条评论:
I have already replaced the battery with one from iFixit, so this is less likely the problem.
完成的
@tanveerzubair Yep, I agree. Can you go over the back of the phone (sans rear panel) with a straightedge? That might give you a clue as to where it's misaligned or out of straight.
完成的
@dadibrokeit Just making sure. Are you asking me to check if the mid-frame is straight?
完成的
@tanveerzubair Yeah, more or less; I was thinking you would want to check the back of the phone with a straight edge to find out where the bend or bulge is that's keeping the rear case from sitting correctly. It shouldn't require pressure to sit perfectly on the phone, so something is interfering, whether that's a malformed midframe or a bent frame or a misaligned connector; something's getting in the way.
完成的
In that case, the bend is extremely minimal, near the volume buttons.
完成的
显示更多的5条评论
添加一条评论
添加你的答案
EverythingAwesomeTech 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 67
总计 67
