跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
Trackpad not working after changing the battery
Hello,
after replacing the battery on my Macbook air 13, i noticed that the trackpad has stopped working, i wasn't careful enough during the replacemnt and i think i damaged some sort of chip
on the trackpad (the one in blue square), now i've already bought another trackpad with the cables, i was wondering if there is a remote possibilty that this is a software issue. Thank you.
BTW the keyboard works fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
How it’s it not working? The tracking of your finger across it fails to show in the movement of the pointer on the screen? Or is it the click action when you press?
这个答案有帮助吗?
得分 0
4条评论:
Yes, nothing works, i can click it, i can finger across the surface, but the pointer won't even show up, i can only use the laptop with an external mouse, but the keyboard as i said works as intended.
完成的
@antoniovit99153 - I would replace the cable and make sure the ZIF connector latch is correctly set (currently in the unlatched state as the cable is not present) once the cable is threaded into the slot fold it back down.
完成的
the pic presented is a stock pic from i fix it, i wasn't able to took a pic before closing the lid, the latch, the cable all seemed not affected, only that chip was a little bit damaged on top
完成的
@antoniovit99153 - Let’s get a picture of your trackpad where the damage is.
完成的
添加一条评论
Well I will suggest you to check out the following: https://discussions.apple.com/thread/252...
这个答案有帮助吗?
得分 0
1条评论:
they say to change the afflicted items and that's what i've done
完成的
添加一条评论
添加你的答案
Antonio Vitagliano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 142
