跳转到主内容
Windows 10 是微软发布 Windows 操作系统的主要更新版本。该系统发布于2015年。
Upgrading Windows 7 to 10 keeping customers data
Since its been along time since i've done this, what im trying to do is upgrade their device to Windows 10 via bootable media, I believe. I want to keep all the desktop icons, settings, apps, data; all in intact as if it were a clone to a new drive. Questions; whats the proper prodecure / way to do this the way I am describing. TIA.
Dustin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There are 2 ways to go on about updating Windows to a newer version while keeping user data:
RECOMMENDED FOR MULTIPLE PCS: You can install the Windows 10 ISO from Microsoft's website, flash it on a thumb drive, plug it in while the OS is running, then run setup.exe, it will guide you on how to keep everything. ( i suggested a thumb drive because i am assuming you are gonna do this on multiple PCs)
RECOMMENDED FOR A SINGLE PC: You can just download the Windows 10 ISO, open it in explorer to mount it, then run setup.exe, should be business as usual.
NOTE:You can't update PCs without having the OS running, booting the ISO is exclusively for new installs.
这个答案有帮助吗?
得分 0
1条评论:
Ty that’s what I was thinking but needed to confirm.
完成的
添加一条评论
Try using windows 10 from microsoft.com, the update that entrails is just the interface being different e.g. the windows logo, microsoft edge, it doesn't completely change your apps.
这个答案有帮助吗?
得分 0
3条评论:
So run the media from desktop non-bootable?
完成的
for the update to work, you would have to update via microsoft.com. your apps will remain the same, microsoft apps such as microsoft edge will be updated.
完成的
also please check if your hardware and software has the requirements to proceed with the update.
完成的
添加一条评论
添加你的答案
Dustin Short 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 43
总计 258
