跳转到主内容
GoTab Android Tablet Advice Needed
Hi all, I'm new to electronics repairing world,
I've purchased 10 x GoTab tablets for spares or repair but can't find a guide on your site. As I'm new are these all made in the same factory with different brands Are all android tablets basically the same under the cover?
Thanks for all help?
Update (04/21/24)
Also I'm after what should be done in the situation. Should I assume that a device that won't turn needs a new battery or check the battery with a multimeter. The items have I presume been in storage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I've also noticed that there are some Versus branded tablets. Also looking at the original advert it states you could make two good tablets from three as all parts are interchangeable and should take 15 minutes to make a working tablet
完成的
添加一条评论
2个答案
最有帮助的答案
get a usb amp meter it will help determine if the tablets are charging
这个答案有帮助吗?
得分 1
7条评论:
Hi apologies for the question what sort of meter should I be looking for
完成的
Thanks for the suggestion
完成的
Have ordered the meter and will let you know when it's arrived
完成的
Hi the meter has arrived . What do I do with it now?
完成的
显示更多的2条评论
添加一条评论
I've been made redundant in my day job and will wating to get a job I will have time to to fully learn how to get know how the USB meter works sand get the original tablets together.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JimEssex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 162
