跳转到主内容
加入维修社区 - 创建账户
Epson EcoTank L3150 Wi-Fi All-in-One Ink Tank Printer
Scaner dosnt work , it's stick.
When i pick to scan , they scaner makes a sound like it's being stuck ando don't make the copy.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
See for any paper jams etc, Head cleaning, ink charging, or ink drying is in progress. Check to see if the Pause light is flashing.
完成的
添加一条评论
1个答案
已选择的解决方案
That is common problem for this type (l3150, 3110, 3210) this problem cause by:
  1. Improper scanner attached to its pin.
  2. Hard stuff/heavy stuff felt down on to the scanner.
  3. Dust accumulate on the scanner tract.
Solution:
  1. Check ribbon scanner cable, whether it is torn uuo or not.
  2. Dissemble the scanner and clean the track, while repositioning the scanner correctly (don't miss even half millimetre).
Hope this will answer your questions.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nahum Alejandro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 570
