跳转到主内容
Boult Audio Z20 Truly Wireless in Ear Earbuds with 51H Playtime, Zen Clear Calling Enc Mic, Made in India, Low Latency Gaming, Rich Bass Drivers, Ipx5
4 个问题 查看全部
One of the earbuds is not charging when placed in the case.
Experiencing an issue where one of the earbuds is not charging properly when placed inside the charging case. I have attempted to charge the problematic earbud using another earbud's case, and it charges successfully. However, it does not charge when placed back in its original case. How can this be resolved?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Proving the earbud is rechargeable points to the charging base. Perhaps a broken or loose wire inside, requiring disassembly.
这个答案有帮助吗?
得分 0
1条评论:
I tried, but no luck.
完成的
添加一条评论
This airpod After charging same time I use 10 minutes it's showing battery low
And discount.. it' problem was battery. So how fixed it
这个答案有帮助吗?
得分 0
1条评论:
I have also same problem bro I think it's buds battery problem
完成的
添加一条评论
添加你的答案
Dhananjay Porwal 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 78
总计 316
