跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac don't start...second LED lights up intermittently every 3 seconds
Hello
Already replaced power supply with the power supply of my other 2012 iMac 27"...and do the same...
Any help to find what is the fault?
Best regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What transpired before you replaced the power supply? Did you alter anything like add memory, replace the CPU…
这个答案有帮助吗?
得分 0
9条评论:
Hello
One year ago (more or less), when reassembly CPU on socket (after replace Thermal Past/Thermal Pads), bent 2 pins on socket (but correct this issue), also "split" Fusion Drive (replaced the Apple "Blade" with a OWC 480Gb and SSD SATA Crucial MX500 2TB), upgraded RAM from 8 GB to 32 GB, replaced PRAM battery(BR2032)... and works great for a year...
Some days ago iMac won't start...I changed the power supply because it didn't start...but don't solved the issue...
Could this be related to the issue of socket bent pins ? (a year ago)
完成的
@boxerboss - Sadly yes 😡 the bent pins are weaker and over time fail. You could try reseating the SO-DIMMs. Do you have an external bootable drive to double check if the current boot drive is messed up. But I’m leaning the socket is the issue.
完成的
Hello
I already removed RAM and put it back in...issue persists
Do you mean to try with a USB bootable Big Sur?(the macOs installed)...and try to start in Recovery Mode?...or Safe Mode ?
完成的
@boxerboss - I just find having a bootable external drive is quicker to just boot up from. You can also try booting up under anyone of the Startup options, do any respond?
完成的
Can I create a "bootable external drive" for my iMac in other Mac?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
JOAQUIM LOPES RAMALHOSA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 129
