跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Dead power button fix
My 2015 MBP has a dead power button. I have determined that it is completely dead at the contact pad as if I touch it with something metal, it doesn't work. Every other key works. Is there something I can do, or does the whole keyboard need replacing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To be clear, you are able to power on the system by shorting out the Power Pads, so it’s clearly the button that’s failed.
这个答案有帮助吗?
得分 0
2条评论:
I haven't tried that. I may have to replace the entire top case.
完成的
@sickminecraft45 - I would start off checking if you can bypass the keyboard first.
完成的
添加一条评论
添加你的答案
Sickminecraft45 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 178
