Whenever I turn on the laptop the screen flickers and shutdown
Whenever I turn on the laptop the screen flickers and then shut down and my laptop screen is alright and my power don't turn on without charger I need plug the charger to use it
It seems like a bad/dead battery, have you tried to keep the laptop plugged in for a while? If so, does your OS show that your battery is 100%
If the above is true, then you should look into replacing your battery, remember that dead batteries can do damage, so fix them asap!
这个答案有帮助吗?
My laptop isn't turning on whenever I start my laptop the screen flickers and caps lock key blinks and then the laptop shutdown and the display is fine
@saudahmadb are you sure that its not a faulty battery with limited charge?, should probably replace it if it only powers on with a charger connected
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 45
