跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
microphone not working after change of screen
Okay my iphone 4 had a smashed screen so i bought another and changed it, everything was good until someone rang me and they said they could not hear me?? but i could hear them, but they could hear me when on loud speaker?
is there anything i could try to resolve the problem or is it a bin job?
thanks inadvance
Arran
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
8个答案
最有帮助的答案
Just do a quick check:
Does the voice recorder still work, does it record your voice.
If the voice recorder also does not record any voice you probably have damaged the microphone, which you can easily replace by replacing the dock connector (which includes a new microphone).
If the voice recorder does work however you have a major (and known iPhone 4) problem with the noise canceling chip on your logic board, which is unfortunately very hard, if not impossible, to repair.
这个答案有帮助吗?
得分 1
1条评论:
hi the voice memo bit does not record any audio??
完成的
添加一条评论
Replace the dock connector mic assembly. Trust me I do this for a living.
Update
You do have to remove the mic/speaker assembly to change the glass. There are 2 screws under it that hold the front glass on. The top noise cancelling mic works on apps voice memos and speakerphone. The bottom mic is attached to the dock connector and works when the phone is up to your ear.
这个答案有帮助吗?
得分 1
添加一条评论
Ic audio broken
这个答案有帮助吗?
得分 0
添加一条评论
I'm having this problem with many phones recently, can't understand it?
这个答案有帮助吗?
得分 0
添加一条评论
http://m.youtube.com/watch?v=prSZ9yJnofY
Try this has worked a few times for me..
If mic doesn't work when on a call and you can't hear them also this is the fix
这个答案有帮助吗?
得分 0
添加一条评论
My iphone has had problems with the noise cancelation mic, does anyone know how to fix the problem... I have iphone 4s
这个答案有帮助吗?
得分 0
添加一条评论
thanks inadvance
DG
这个答案有帮助吗?
得分 0
添加一条评论
thanks inadvance
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arran 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 6,441
