Controller Won't power with rumble motors connected
My series controller wont register if I have the rumble motors connected to the pcb board but works just fine if I leave them unsoldered. I have2 doing this
Hi Dale!
Hmm.. this is new! Could you share some pictures regarding this (as how it is soldered)? Looks like it’s shorting your motherboard… if everything is soldered correctly, I advise to replace them and see if that solves the issue.
这个答案有帮助吗?
Hello replaced them both twice,no luck. Took them back off they both work fine thx
Hmm weird. The only thing I can think of that it’s shorting… must be motherboard related, if the replacement part is giving the same fault.
Ok thank you I do believe a couple of components are bad . I'll let you know if I figure it out
Alright, please keep us posted! Good luck!
Started working after a few resolders, until you press the triggers and the controller vibrates then it shuts down . Then it starts back up with the smaller motor running slowly then it has the start up vibrations and runs fine until you touch the triggers again . Still working on them I've got 3 doing the same,its in the joystick pcb somewhere as I tried them in a working controller and it reduces that one to the same thx
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 184
