跳转到主内容
加入维修社区 - 创建账户
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
iMac Pro / Motherboard dead / No leds on
Hi everyone, I have an issue with my imac pro. It doesn't start anymore.
I have no leds light on motherboard. I already changed power supply but same thing. Thank you for your help.
Regards
Update (04/19/24)
Mise à jour...
Je me suis rendu compte qu'il y avait un bouton sous les leds sur lequel il faut appuyer pour avoir l'état.
Seul la première led s'allume. J'ai également essayé de me connecter en DFU et j'y arrive par contre j'ai une erreur quand j'essaie de restaurer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
8条评论:
I have the same issue. Power supply is good, power does come in to the power supply but the LEDS are out.
完成的
Under and to the right of the leds is a push button. The leds will not enable unless this button is pressed.
完成的
Spanish:
Yo estoy en la misma situación, si alguien puede facilitarme el esquema de conexionado y de tensiones se lo agradecería.
English:
I'm in the same situation, if someone can provide me with the connection and tension scheme I would appreciate it
完成的
We have limited information on the iMac Pro system. Here’s a deeper view internally iMac Pro拆解.
Sadly I never was able to locate schematics and board view drawings for this system. With the logic board number (820-00967) you might google it to see if your luck is any better than I had. I was only able to find this 820-0067 Component Identify thread which offers a link to the schematic but it’s damaged.
I would start off making sure the power cord and power supply are good. As most of the failures are due to power surges or lightning strikes. There are a few onboard diagnostic LED’s you do need to press the small orange button just below the five LED’s.
完成的
显示更多的3条评论
添加一条评论
1个答案
I would check the AC socket as well as manually short the power button line to see if the button has failed as well as check the power rails.
It’s also likely you have a short within the logic board logic. You need the schematics and board views to work this out.
这个答案有帮助吗?
得分 0
2条评论:
@danj exactamente estoy buscando donde repararlo no me importa pagar por la información.
Exactly, I'm looking for where to repair it I don't mind paying for the information.
完成的
@antoniofer31583 - Ideally, you want to find a local shop, you may no choice other than Apple.
Lo ideal es que busques una tienda local, y puede que no tengas otra opción que Apple.
完成的
添加一条评论
添加你的答案
Olivier Paulart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 459
