iPod won't turn on or off?
My iPod's screen is frozen. It won't turn on/off or anything what could be the problem/solution?
Press and hold the middle button and the menu button at the same time. This should perform a hard reset and unfreeze the device.
这个答案有帮助吗?
My iPod has had similar issues in the past, in which even a hard reset would not work. If that is your case, just let it drain itself dead and then charge it back up. You should be good to go then!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,254
1条评论
Is the little switch on the top in the "Lock" possition?
由 Chris Green 完成的
