跳转到主内容
加入维修社区 - 创建账户
Why is it dead?
Okay, long story short.
This started as a simple screen repair. The customer had sat on his laptop, and the screen was cracked. I swapped the screen, and it worked.
A week later, it has a new problem. No chime, no post, vertical lines on screen and then nothing but backlit black.
Okay, so probably not a screen problem then, seeing as there's no post. I try an external display, nothing. So it's gotta be the board, most likely cpu/gpu (due to artifacting), right?
EVERY LINE TESTS NORMAL.
okay, so I swap the board anyway, because everything's tested normal but maybe the power rails got temporarily bridged and it fried the cpu or something (i know its unlikely, but im just clutching at straws at this point).
no change. Fans come on full power, no post, vertical lines on screen, and the light on the charger stays off.
WHY
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
When the fan comes on at full power, that's a sign of a defective heat sink.
When the thermal sensors stop working on a Mac, the sensors essentially tell the SMC at startup that Mac is on fire. So, the SMC will not let the Mac boot, and it only spins the fan at high RPMs to try and cool down the system.
这个答案有帮助吗?
得分 1
3条评论:
That's interesting to know, and makes sense. I think this is likely, but there's probably also something else going on as well (purely because of the other issues such as lines and the charging light not coming on--I know the lines indicate gpu and the charging light indicates onewire, but *every reading gives the expected value* and I've tried 2 different boards and heatsinks now).
I've decided at this point to abandon this repair, give the customer the money back for the screen even though that work was good (as they don't have a functioning laptop) and make them aware that the it's probable that the cheapest outcome for them is going to be buying a replacement a1466 (which the money back from the screen basically covers anyway) which I can swap the drives on for free as a courtesy.
Leaves me slightly out of pocket but with far less of a headache in the immediate term.
完成的
@donewithit You picked right on that one. I think just doing a simple data transfer with their new laptop should be fine with them.
完成的
@donewithit - Let me correct @jadonlyon here First off you really need to run the onboard diags to hopefully ID the failure, if not then the issue is external of the logic board, so while their might be a heat sink issue as well the issue is still within the display as you claim "vertical lines on screen" which is the breakdown of the driver lines to the LCD panel.
To test things you would need to run the system in Clamshell mode using an external mDP/TB display and keyboard & mouse. The reason you need to use these external devices is you need to have the internal display closed to enable the external. While you can cheat using a rare earth magnet passing it over the Hall sensor which is mounted on the back side of the I/O board in this series back side of I/O board note that component between the headphone and TB ports.
完成的
添加一条评论
添加你的答案
Donewithit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 161
