跳转到主内容
Repair information and guides for the minor refresh of the Late 2018 MacBook Air, with the same model number (A1932) and EMC number (3184). This model features a True Tone display and a slightly revised battery.
Overheating Problem that doesn't go away no matter what I do :(
Hello! I'm trying to fix an 1932 Macbook Air from 2019, but I've been struggling with overheating. It heats up to 90-100 degrees Celsius on startup, then goes down to 30-45 on idle, after the fans sit in full blast for a while.
Whenever I do anything on it (like open a file) the temp immediately jumps up to 60-70 degrees Celsius.
Whenever I start a graphically-intensive process (like open a PDF with images, launch a browser, open multiple images, etc) the temp quickly jumps to 80-90 Celsius.
In both cases, it needs the fans running at 8000 rpm for like 10 seconds to cool back down.
I'm using Macs Fan Control to monitor the temperature, and I set my own automatic rules for the fans to kick in earlier.
Even so, the computer often goes into kernel panic due to overheating and restarts (can't use it for more than 1 hours without this happening). I can provide the reports if you think it'd help, the only common thing between multiple reports I've noticed is that the process responsible is usually kernel_task, though I'm not sure that adds anything.
Here's what I tried so far:
  • Cleaning the insides of the laptop, fans, etc, it's spotless in there.
  • Replacing the thermal paste.
  • Resetting device, and reinstalling macOS
  • Resetting the SMC
Replacing the thermal paste had an impact, it lowered the idle temperature from 40-50 to 30-45. But I still get the kernel panics.
Considering all the symptoms, What would you think is the problem? I can't notice any damage or problems around the CPU/GPU, and since the laptop functions, always gets past POST, etc, I'm not sure if it's a motherboard issue.
I was thinking the fan might be the problem, but that too looks fine on visual inspection.
My last recourse was to change the battery - I was thinking there might be a problem with its board, sending too much power to the GPU? Is that possible, should I consider it?
PS: Nothing comes up while doing Apple's diagnostics. Problem persists in safe mode, with no peripherals connected.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
unfortunately this is the way A1932/A2179 is designed. Your CPU is slightly degraded now, so it generates more heat. Putting a big thermal pad on top of CPU heatsink to + removing plastic sticker on bottom plate will reduce temps by 20-30C, however you will have very hot spot on your back cover.
Other option would be to try to find a dead i7 logicboard, they had better copper heatsinks.
In both cases keep your data constantly backed up / clouded, next step is usually a dead CPU.
这个答案有帮助吗?
得分 1
2条评论:
Thank you! Will try this and come back to update on the results. Do you think a thermal pad + copper shims will have better results? Like they do here: https://forums.macrumors.com/threads/202...
Do you have any recommendation for thermal pads/shims?
完成的
well, i used some random pads which came with SSD drive and it was able to keep CPU under 85C under full load (i also adjusted macsfancontrol to keep CPU under 95C
完成的
添加一条评论
添加你的答案
TheoP 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 96
总计 1,579
