@shanespangler sadly enough that sounds like a board problem, are the two gold plated connecters in the spot where the speaker is when you take it out at all discolored?
So you could try to look under the space for it, it could be board issue. But for some reason whenever I say it is a board issue someone with like 500k rep comes in and turns out I'm wrong (no hate to them tho) so take my words with a grain of salt
Does the selfie camrea work?
由 Hampter 完成的
@hampter It does. There is also the issue of the flashlight not working because it says the camera is using it, even though the camera is disabled.
由 shane spangler 完成的
由 Hampter 完成的
@hampter If I remember correctly, they didn't look discolored, but I could be wrong.
由 Hampter 完成的
