跳转到主内容
2020 年 3 月发布的配备英特尔处理器的 MacBook Air 型号 A2179 2020 更新版的维修和拆解信息。
107 个问题 查看全部
Webcam connector location on A2179
Hi,
I have replaced the screen assembly on a MacBook Air early 2020 (A2179) and there is a note on the back of the screen advising to make sure the display and camera connections are correctly connected.
Is this the same connector for both? As I can only see one connector that I removed when I took the screen off.
Also, I need to test it but can only use the guest account until the owner returns on Friday. Does the standard guest account have permissions to use the webcam?
Thanks in advance,
G
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are five cables involved with the display:
You have the four from the display connecting to the T-CON board and then you have one cable coming from the logic board to the T-CON.
If the display is showing that validates the two wider display cabled and the video side of the logic board cable. That leaves one of the smaller cable connections from the display which is the camera feed and the other is the display back light feed. If you look carefully the copper lines are bigger on the backlight cable.
That then leaves the logic board or camera cable which could have damaged connector contacts or traces within the cables.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gerald Bowen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 40
