跳转到主内容
DJI RC-N1 Remote Controller (also known as the RC231) Model RC231 Compatible with DJI drones: Mini 3 Pro, Mini 2, Mini 2 SE, Mavic Air 2, Air 2S, Mavic 3, Mavic 3 Cine.
Don’t keep it charged
I got a “new”drone, verry chep, and I have now found out, I need to have a power source to the remot.
I have changed for 5H the let it rest for 1 day. But still won’t power on.
But if am using a USB cable connection to a power supply it works like a charm.
Any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @danielbernesdsd
Try replacing the batteries in the controller.
Here's the ifixit DJI RC-N1 Remote Controller Battery Replacement guide that shows what to do.
Search online for 18650 battery with connector (supplier examples only) to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
2条评论:
So you are think it’s the battery?
And not the chip in the remote that is bad,
完成的
@danielbernesdsd
If it works with the charger connected but not when on battery only, it may be the battery management circuit (if this is what you meant by "chip") but more likely it will be the batteries.
Even rechargeable batteries have a lifespan. They don't last forever ;-)
You said that it is "new" but this doesn't mean that it hasn't been in storage for a long time and the batteries may have become depleted beyond recovery.
Sometimes you can "kick start" them back into life by leaving the charger connected for some 3-4 hours and then they may start recharging and work OK but since you have tried charging it for 5 hours and still no good, this suggests that they can't be revived.
Since it is new you could try contacting the seller and ask them for a replacement or a refund as it should have worked straight out of the box.
完成的
添加一条评论
添加你的答案
DANIEL bernesdsd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 390
