跳转到主内容
27寸 iMac 的维修指南和支持
3414 个问题 查看全部
Turning 2012 model to 2019 LG display is the case same?
Hi, have 2012 Imac 27, but is getting slower and slower,I would like to upcicle and use it as monitor with replacing screen for LG 2017 5K original display which came to 2019 models (more nits than previous model) install logic board and connections.
Questions
is case/chasi from 2012 same as 2019, so it can use the same display 2019?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Did you try to give the old iMac new life? Install a newer OS, even the newest using Open Core Legacy Patcher. There are lots of Videos and a guide at iFixit. The procedure is time consuming, but doable, my old Mac works like new!
这个答案有帮助吗?
得分 1
添加一条评论
There are kits to convert your system into a display only, basically salvaging the case and the display and gutting out the rest.
As far as sliding in a 5K display I think thats going a bit far unless you have access to the display presently as the costs would be more than getting a 3rd party 5k display
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lukas Bis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 18
