Cable between battery and cam
Hi to all,
I bought a used iPhone 14 with already replaced battery. Sometimes it is charging correct and sometimes it paused because of hot battery. But it is not hot! Not even warm. I already ordered a new battery from here (but not delivered, yet).
I opened the iPhone to have a look and I found some scratches on the cable (or thin, tiny, black board) between battery and rear cam. It is connected beside the wireless charging cable.
I think it get those scratches from getting the old battery out of the phone.
Is here a temp sensor on this cable and make this strange problem? What is the name of this cable? Can I buy a replacement here or somewhere?
Regards
Patrick
Hmm, I think it is just a thin, black metal separator. No cable, no sensors on it. Just metal separator mounted to the frame.
I hope it’s a bad replacement battery and it’s done with a new one from here. Never hat an issue with a battery from ifixit since iPhone 4s.
由 Pättes 完成的
You are correct, that is the walls of the battery bay
由 Hampter 完成的
It only thinks to heat up. This phone is still cold. I know how a warm iPhone feels and this one isn‘t even a littlebit warm. I will try the new battery and if the problem still exist I‘ll try the charging port. Thanks.
由 Pättes 完成的
