跳转到主内容
A smart entry system is an electronic lock that controls access to a building or vehicle without using a mechanical key.
My remote stopped working can it be fixed
I changed the battery didn't work also in the morning it worked but in the afternoon it didn't
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Lawrence, not much we're going to be able to do to help without knowing just what it is you've got there. What does the remote control? Is this a factory or aftermarket remote? Is it RF or IR (radio or infrared)?
完成的
添加一条评论
1个答案
Try using some WD40 contact cleaner on the buttons. Remove the batteries first and then spay the cleaner on all the buttons and then press all the buttons a few times so the cleaner seeps in. Put new batteries in the remote and then retry. Do not use the normal WD40 it has to be (WD 40 contact cleaner)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lawrence Kentfield 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 171
