跳转到主内容
MBA M1 A2337 - Dead Wifi?
Hello everyone !
I have a Macbook Air with quite the unusual issue, I believe I shorted the small parts highlighted in red in the picture below while doing a screen replacement on my unit. (It made funny sparks when the antenna cover slipped....)
Now, the system won't let me activate wifi on the device. I had to use an USB to Ethernet adapter to perform device recovery (It was not booting prior to screen replacement, pink screen and bootloop)
I tried to see if any part was fried on the front side of the logic board but to no avail, I'll try to remove the logic board from the device to check the other side tomorrow
I'm thinking of a logic board repair using a donor board, I'm probably gonna look for a repair shop to do that for me as I'm not that much DIY nor correctly equipped. I'd love your input though regarding the issue, if you already encountered in the past and which lines might be at fault here.
Thanks !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The capacitors that you marked have to do with the LCD backlight circuit, but it's possible another component was damaged. Are you sure the antenna cables are properly connected? Do the antenna connectors on the logic board appear damaged in any way? Are you able to connect to WiFi in Safe Mode? Good luck!
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the swift answer Zach !
The antenna cables are properly connected although even if they were not, the device should still be able to detect Wi-Fi ; it's the first theory is explored when I encountered the issue ; they have no hardware in them, it's just a long metal antenna.
Antenna board connectors aren't damaged neither, they're the part I hate the most in any disassembly but I made sure to be careful with those.
Lastly, nope, in DFU Mode or Recovery Mode, when I reach the "Activate Mac" screen, Wi-Fi wasn't showing up at all. I had to use an USB C to Ethernet adapter to be able to activate the device and reinstall Mac OS
Total darkness haha
完成的
添加一条评论
添加你的答案
Simo Hakim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 25
