跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 个问题 查看全部
How to reconnect left hinge to the rest of the hinge?
The display from my Mac has a broken hinge. The left part of the hinge is disconnected from the rest of the hinge. How would I reconnect it? I don't care about the cosmetic appearance of the hinge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's hard to tell from the picture how exactly the hinge has broken or if it would be repairable. If the screws have come loose but all of the actual hardware is still in tact then you make be able to use it. Otherwise, you might have to remove the display, remove the display hinge, and fully replace that particular broken hinge (which I believe also includes the display cable). Here's a guide for how to do that on the 13-inch model, which I think is a similar procedure for the 15-inch. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peap Wu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 12
