iPhone 14 Plus Kernel panic
I have an iphone 14 Plus that is constantly kernal panicing. It has not been cracked or water damaged. The rear cameras and flash do not work for some reason. I have checked the connectors and have attempted to restore the device. However, the device fails to restore unless I unplug the flex cables except for the dock/battery/screen. I have attached the log, any idea what is causing the panic?
2条评论
Here is the full panic log. https://pastebin.pl/view/0abc132e
由 CAB 完成的
Using Apple's Mobile Resource Inspector diognostics tool only showed that the rear cameras could not be detected. Will the device keep Kernel panicing if the camera is faulty/unplugged? The flash doesn't work either but wireless charging and the mic works, could the flash just be disabled by iOS?
由 CAB 完成的
