跳转到主内容
The Miyoo Mini Plus is a larger version of the Miyoo Mini.
1 个问题 查看全部
My miyoo mini plus’ screen is freezed, how can I fix its?
Basically today I started my miyoo mini and started a Nintendo ds game, I left it on the table for the time to go make some coffee and it went into standby mode. when I turn it on now the screen is on the Nintendo ds mode but it won’t work and any button does seem to work but it doesn’t. I really love my miyoo mini and I’d love to fix it. I’ve tried everything but it won’t work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I had the same issue stuck on a DS game after it had gone to sleep mode. Had to insert the SD card back into my PC and delete the ROM file of the game that was stuck for it to let me off the glitched screen and back into the Game Switcher.
Not ideal for those that had saves they wanted to retain. Seems like a bug in 4.3.0 of Onion
这个答案有帮助吗?
得分 2
添加一条评论
Hi @giacomocastaldo
If you haven't already done so, try disconnecting the battery from the device for about 30 seconds and then reconnect it and check if doing this resolves the problem.
Here's the ifixit Miyoo Mini Plus Face Buttons Replacement guide that will help.
You only have to go as far a Step.3 in the guide to disconnect the battery
这个答案有帮助吗?
得分 1
2条评论:
Hi, thanks I’ve tried but it still won’t work. It is still freezed to the Nintendo ds screen.
Now some things might work but it still won’t get out of that loading screen.
完成的
@giacomocastaldo
Don't know the device but if it has a Power button or an On button, disconnect the battery once more and this time press and hold (or turn on) the Power/On button for a full 30 seconds and then release it. Then reconnect the battery and check.
完成的
添加一条评论
添加你的答案
Giacomo Castaldo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 144
总计 219
