跳转到主内容
Repair and disassembly information for Google's Pixel 8 smartphone, released in October 2023. Identified by model numbers G9BQD, GA04851-US, GKWS6, GPJ41, and GZPFO.
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
完成的
添加一条评论
1个答案
最有帮助的答案
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone.图片
产品
$3.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Grayden Hormes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 196
