跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 个问题 查看全部
screen having lines in homescreen and games
I got a second hand 3DS with a somewhat problematic screen as it has lines or even blacks out in games and home screen but whenever I enter homebrew software that issues goes away. Is it because of the screen's ribbon being faulty or is it the LCD in general? if so should I replace the screen? I put up an image for reference!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
so first you want to do is remove the upper lcd, then replace it with a new one
if the problem is still there, clean the top screen zip connecter with some isopropyl alcohol
if its still there, check the top screen ZIF connector. Look it over carefully and make sure there aren't any bent/broken pins or cracked solder joints.
这个答案有帮助吗?
得分 0
2条评论:
okay i will try that! thank u!
完成的
No Problem, if you need help, message me
完成的
添加一条评论
添加你的答案
Fathansolo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 84
