跳转到主内容
Released March 2021, this model features lidar, a gravity-fed vibrating mop pad, and mop pad lifting using an ultrasonic carpet detector.
Roborock s7 - side brush keep falling while in use
Hey,
My Roborock S7 is 2 years old and lately, the side brush started to fall off during operation.
I keep finding it in different areas of the house, this is annoying.
When locking it back again, it feels like the screw is tight.
Any idea how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I had the same problem with mine. used some super glue. can recommend
这个答案有帮助吗?
得分 0
1条评论:
super glue?? and what happens once you want to change the brush?
完成的
添加一条评论
I also had the same problem with mine.
After screwing it on several times, I decided to use a little dab of Loctite.
I really can’t recommend that because it almost certainly led to the failure of the side brush motor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rot253 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 878
