跳转到主内容
Dryer turns on but trips breaker after replacing heating element
Model number MEDB765FW0
we replaced the thermal fuse and heating element because dryer wasn't blowing hot air anymore. now it will turn on and heat but after 30 seconds running it trips the circuit breaker on the electric panel. What could we have done wrong during our installation to cause this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @deniseg480
Check that you haven't jammed any wires against the frame of the dryer, connecting the supply voltage directly to earth and tripping the breaker.
Looking at the wiring diagram on p.24 of the tech sheet, when the motor gets up to speed the centrifugal switch in the motor completes the power path for the heater circuit.
If you have a DMM (digtial multimeter), unplug the dryer from the power and then using the Ohmmeter function in the meter, connect the meter to one side of the thermal fuse or heater and the frame of the dryer (bright shiny metal point) and check if there's any resistance showing on meter. It should not indicate 0.00 Ohms i.e. a short circuit. Also make sure that the heater element itself is not short circuit as well.
Just what I'd try
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
DeniseG 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 22
