跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
116 个问题 查看全部
Trackpad and Keyboard not work
A2338, after sometimes trackpad and keyboard not work, and USB keyboard and mouse work all time,
changed UT360, UT301. Diode value dropped in PP1V85_S2_IPD from 443 to 200. then i will replace that both IC and again value increase. same repeat. any idea, what to do,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you replace the trackpad cable?
这个答案有帮助吗?
得分 0
3条评论:
yes new track pad cable and also new track pad.. both not working.
完成的
@vijaypatel017 - Sorry you’ve changed so much, I don’t know where to even start here. Rarely do I find my self changing our parts without a firm grasp of a diagnostic process that compelled me to change out parts which haven’t any physical damage or corrosion visible.
What is the history? Did this get liquid damage at some point. While you replaced the trackpad the keyboard or even keyboard cable may be bad.
完成的
thanks for reply,
Yes it has a liquid damage near charging circuit, also near track pad IC, and keyboard cable burn, so i have replace keyboard, then correct charging circuit , charging and discharging work ok, then i have also replace trackpad IC UT360 and UT301 also, and also nearby capacitor CT360, CT361, CT400, LT400, CT302, CT303.
and nearby CT302 and CT301 capacitor minor track damage, i have corrected and fix it.
after correcting trackpad and keyboard work sometime may be 5 to 6 hr, then both stop, but external mouse and keyboard work ok alltime.
and sorry for late reply.
完成的
添加一条评论
添加你的答案
Vijay Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 47
