跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
Display Issue After Replacement: Only Backlight Visible
Hello everyone,
I recently replaced the display on my iPad Air 4 and encountered an issue where only the backlight of the screen is visible. Despite the touch functionality seeming to work fine (I can hear the device respond to touch inputs), there are no icons, colors, or any visual output on the display itself, just the glowing backlight.
Here's a rundown of the situation:
  • I have used 2 replacement screens from iFixit for this repair, the same issue occurred with both screens.
  • I ensured that all connectors were properly seated during each display assembly attempt.
  • I checked for any visible damage to the connectors or the ribbon cables.
  • I attempted a hard reset to rule out a software-related issue.
Despite these efforts, the screen continues to show only the backlight without any actual display content.
Has anyone here experienced something similar or have any suggestions on what might be causing this and how to fix it or if there's a specific aspect I should be paying attention to?
Thank you in advance for your insights and advice!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I've had this happen on some repairs in the past. In my experience, I caused a static shock to the board that blew out the backlight IC chip and required microsoldering to repair. It usually happens due to the battery not being disconnected while attempting to plug in the screen. You will see the image on the screen but very dim and you will hear all the noises coming from it, but difficult to see the image.
Diagnostic Steps
  • Test with known good parts
  • Test with the original screen
  • If still no backlight, do a visual inspection of the board.
  • Look for blown diodes (likely will be cracked)
How to Fix
  • Replace Backlight Diodes (if blown)
  • Replace Backlight Fuses (if blown) that are next to the FPC connector.
这个答案有帮助吗?
得分 0
1条评论:
Matt, it appears to me the poster has the opposite problem from what you're describing. Rather than having a picture and no backlight, they seem to have a backlight and no picture.
完成的
添加一条评论
添加你的答案
UA - Gianluca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 206
