跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
116 个问题 查看全部
MacBook stops working after changing screen
Hello. Yesterday I changed the screen on my 2020 M1 macbook pro and something strange happened. The computer apparently stops working and not even an external screen recognized it using HDMI when it did recognize it with the old broken screen. My surprise was that when I reconnected the old broken screen, the Mac worked again and the external screen recognized it again.
The only thing I can think of that could happen is that the new screen comes with the brightness disabled and then looks black (my computer also has a broken touch bar so I can't try increasing the brightness) anyway this is just a hypothesis.
Any idea why the computer apparently stops working and doesn't even recognize the HDMI connection when changing the screen?
Thank you very much for your time
all the best
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like there could be a fault with the new display you installed. That sometimes happens, especially when purchasing through third party retailers online. Some things to consider: Was the battery disconnected before you replaced the display? Are you confident it's the correct model display? Do you have the ability to return the display and get another one? Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Juan Carlos Medina Franca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 50
