跳转到主内容
新 Nintendo 3DS 是 3DS 产品线中第一款大幅更新的迭代设备。在日本于2014年10月发布,北美市场于2015年9月发布。2015款 3DS 改进 3D 显示性能,全新 C 摇杆,内置 amiibo 读写功能,以及全新的4肩键配置。
What makes the ABXY board to stop working?
One of my 3ds systems (new 3ds) used to work normally, but all os sudden it didnt turn on anymore (only if plugged in but didnt charge)
I took it to some repair shops but every shop told me that the repair wasnt worth it since the system needed a new motherboard.
I left the 3ds aside for some time, but didnt give up and kept searching online for a solution. After a long time i found that a possible solution was changing the ABXY board.
Since it was a cheap solution i decided to try it out. And it Worked!! But not for too long :( after one day or two it stopped working again.
So, what may be causing the abxy board to stop working? I want to fix my 3ds :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
I would start with this guide and look for damage then give us images to give you a better diagnosis and hopefully a working 3ds in the end.
Nintendo 3DS 2015 C-Stick Replacement
在已经存在的问题里加入图片
完成的
So after changing the ABXY board again, my 3ds is now working and charging.
Later, i will turn it off an on again to see if it keeps working.
完成的
添加一条评论
1个答案
The ABXY board may only be making partial or no contact with the contacts on the circuit board. If this does not work, you may want to use an eraser to clean the button contacts.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JAFA13245 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 161
