跳转到主内容
加入维修社区 - 创建账户
发布于2013年11月22日的微软第三代Xbox游戏主机。
My xbox won't output the image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If your Xbox isn't outputting an image, here are some troubleshooting steps you can try:
1. Check Connections: Ensure that both your TV and Xbox are powered on and that the HDMI cable is securely connected to both the TV and the Xbox. Make sure the HDMI cable is plugged into the "out to TV" port on the console.
2. Correct Input Signal: Verify that your TV is set to the correct HDMI input signal.
3. Power Cycle: Turn off your Xbox by holding the power button for 10 seconds, then turn it back on.
4. Reset Display Settings:
• If there's a disc in the console, eject it.
• Press and hold the Power button on the front of the console for 10 seconds to turn off the console.
• Press and hold the Power button and the Eject button until you hear a beep to turn on the console. You’ll hear one beep right away and a second beep 10 seconds later. The power light will flash on before the second beep. Don’t let go until you hear the second beep or see the console start up in low-resolution mode.
  1. Try a Different HDMI Port: If possible, plug the HDMI cable into a different HDMI port on your TV.
    1. Use a Different HDMI Cable: Sometimes, the issue might be with the HDMI cable itself. Try using a different cable to see if that resolves the issue.
      1. Test with Another TV: To rule out the TV as the source of the problem, try connecting your Xbox to a different TV or monitor.
If these steps don't resolve the issue, it might be necessary to contact Xbox support for further assistance.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ahmadqadous 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 129
