跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
173 个问题 查看全部
iPhone motherboard current fluctuation
Hello! I got an iPhone 12 that does not turn on. No visible damages, no breaks, no water damage. Took it apart, connected to a dc psu, no current draw without booting. With trying to boot, it starts to draw a weird amount. It fluctuates between .400 and 0, with like 2 different spikes starting from each end, getting close to the other end, then back, and the cycle continues. Here's a vid about it:
https://youtu.be/BXc8cXyvBLs
It doesn't get hot (at least not on the upper side of the board), my sandwich heater didn't arrive it yet, and I dont want to take it apart unless it's necessary. Any ideas what could be wrong here?
Any help is appreciated!
Have a nice day!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
any shorts around nand ?
这个答案有帮助吗?
得分 2
9条评论:
A short around the nand would cause symptoms like that?
完成的
@abel11493 its possible, check for low resistance on caps
完成的
And what do I do, if I find more than one shorted caps? Meaning that the line is shorted, but how do I find the faulty cap, or the other source of the short? Perhaps if it doesn't generate outsanding heat, it could be under the nand, like 2 solder balls joined together?
完成的
@abel11493 you would need to inject voltage and either use ipa, rosin or freeze spray. failing that a thermal camera
完成的
There are more then one shorted lines. Mostly around the PMIC. The PP1V2_IO, PP_SRAM_S1, PP_CPU_PCORE, PP_CPU_SRAM, PP_SOC_S1, PP_AVE_S1
PP_CPU_ECORE(this one has like 0.3 ohms to ground)
PP_GPU has ~12ohms to ground.
How is this even possible?
Now when I try to boot, it the current jumps up all the way for a fraction of a second, then back to 0. When I let go of the button, it jumps up again, but then back to 0 again. If I repeat this quickly a few times, the PMIC gets really hot around H4 pads. Is the PMIC faulty? Or is it something else?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Abel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 73
