跳转到主内容
Technical specifications and repair procedures for the MSI GeForce RTX 3070 VENTUS 2X OC. Released on September 11, 2021.
1 个问题 查看全部
GPU Heatsink Thermal Pad Thickness?
Does anyone know the correct thermal pad thicknesses for these cards? I have found conflicting information and haven't been able to find firm answers, since there are so many variants. Even going directly to support, their response doesn't seem accurate to what I found when I removed the heatsink.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you measured the thickness and accounted for probable compression you should be able to relate that to an available item. Personally, I would attempt to use thermal paste, but there might be a voltage diff across it. I'm not sure why pads are used in place of paste.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 34
总计 120
