跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
150 个问题 查看全部
1 usb port non-functioning?
had a customer come in, wasn't charging. Used shop cord, charged right up on one of the two ports. Port closest to hinge not working for power or data. No biggie, right? Wrong. Replaced the port assembly and still no change to the lack of use on the usb port. Is there a component on the board that could be causing the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Absolutely.
Every port, or input will have components on a circuit board that regulate its function. First thing I would do here is inspect the old USB-C board, if you still have it, as well as the area on the back side of the logic board.
May times there could be damage to the port where pins where bent, or corrosion crossed some lines and did some damage to the USB controller affiliated with that port. You may be able to see physical damage or blown components in this area. It's the flip side of the board from the USB board connector and most of the components here are related to USB function. The two large chips are the controllers for the ports, which also assist in negotiating charge, but I would lean towards something else in this case. A bad chip in this pair can cause the device to not power at all.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nelson Leach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 23
