跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
Leaking from Rotor underneath
Model: wtw7300dw0
My machine is leaking from the rotor during certain drain cycles. But not every drain cycle. It does not leak when I do Mixed/presoak/extra rinse. It leaks on any other cycle.
Where do I begin solving this? What parts should be replaced? Is it more worth it to just purchase a new machine?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Meren,
One good thing I've found about appliance repair is that there are several appliance parts sites that also have repair help sections associated with any given model.
In your case, I found a page on partselect.com where a user specifically asked about the same issue as yours. Where you see the water coming from is apparently called a "slider", part number W10734521. Here's what it looks like.
The question was posted on the Questions and Answers section of the parts page for your model. I entered the word "leaking" in the search bar and this Q/A came up.
From looking at the slider part, it is described as being used to fix the case where the machine doesn't agitate, so I suspect it won't help with your leaking situation. However, the gearcase that the PartSelect guy mentioned sounds like a very likely culprit, as it has a seal at the bottom. I imagine if you take off the slider part you should be able to see if that gearcase is leaking or not. Here's the part and a picture of it.
Official Whirlpool W11393685 GEARCASE
If you want to take a chance, there are also used ones available on eBay starting at about $85; that's entirely up to you if you want to take a chance on a used product. Personally on something like this I would go with a new replacement part, but that's just me. There are also new ones that can be had on eBay, but they start at about $150, so there's no advantage to buying it there versus the parts company I mentioned already.
So there you go; my best guess is that you can fix it with a $150 part and some labor on your part. For me it would be an easy decision to repair rather than replace and I would encourage you to consider that, but I understand that tearing apart an appliance isn't necessarily something everyone has the skills, experience or inclination to do.
Good luck with your repair; let us know how it all turns out for you!
Facilitates the spinning of the washer basket during the spin cycle.图片
产品
W10734521 - Washing Machine Shift Actuator Kit
$43.99
Links the spin basket to the drive motor in your washing machine, enabling effective spinning and agitation.图片
产品
W11393685 - Whirlpool Washer Transmission Gearcase
$170.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Meren Marciniak 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 12
过去 30 天: 26
总计 818
