跳转到主内容
The Acer Aspire 4520-5464 can be identified by its model number: LX.AJN0X.010. It was released in October of 2007, and came equipped with an AMD dual-core processor and a 14.1” screen.
3 个问题 查看全部
Why my Aspire 4320 Series enters a command screen when turned on?
My Acer Aspire 4320 Series enters a command screen every time I turn it on and the following text repeats over and over:
Broadcom UNDI PXE-2.1 v9.4.5
Copyright (C) 2000-2006 Broadcom Corporation
Copyright (C) 1997-2000 Intel Corporation
All rights reserved
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Broadcom PXE ROM.
Operating System not found
(I know this is the forum for the aspire 4520 but the 4320 forum doesn't exist yet)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ianpcampos
The message you're getting indicates that either the HDD has failed or the MBR (Master Boot Record) files on the drive have become corrupted so it cannot boot into the Operating System.
Start the laptop and try to get into the BIOS menus by pressing the F12 key rapidly a few times.
There is only a small window of opportunity to get into BIOS and it is usually when the manufacturer's splash screen logo is on the screen and before it goes to boot into the OS.
If you can get into BIOS check if the HDD is shown as being detected by the BIOS i.e. model number of HDD etc.
If it is being detected then hopefully it is only corrupted MBR files on the drive. If there's no HDD detected then most likely the drive has failed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ian P. Campos 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 27
