跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
478 个问题 查看全部
iPhone 11 Reboots Panic log
"panicString": "panic(cpu 0 caller Oxfffffff01f8c85a4): userspace watchdog timeout: no successful checkins from thermalmonitord (2 induced crashes) \nservice returned not alive with context: is_alive_func returned unhealthy: current 3bfffffffffff, mask iffffffffffff, expected 1ffffffffffff. SD: 1 BC: 1 RC: -1 BS: 1, Missing sensor(s): mic2 \nservice: backboardd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: audiomxd, total successful checkins in 197 seconds: 18, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins in 197 seconds: 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord (2 induced crashes), no successful chooking in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is a rather common issue in the iPhone 11 specifically. There is an entire page dedicated to these sort of kernel panics, but I'll cut to the chase.
Your iPhone is expecting a check in from a sensor and because it's not getting the expected data, it reboots. The sesnor referenced in your log is "mic2" which is the rear microphone. In the iPhone 11 this can be found on the power button flex cable. This cable also contains the camera flash.
It's best to replace this with an authentic Apple cable (there are places that sell cables pulled from good phones), or part from a reputable seller. There are many of these parts on the market that will continue to produce this issue, even after they are replaced.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jrf89 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 40
