跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Mac Mini 2014 missing bottom cover. is this a problem?
I have obtained a mac mini 2014 that is missing the plastic bottom plate cover. Is this a problem? Does this block airflow, and if so, would this be mitigated by adding feet to the base of the mac to give raise the device a little to allow air circulation? are there any other issues that will need to be worked around?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'd recommend adding the feet onto the Mac as it would allow for improved airflow into the device. But other than that I don't think it should be too much of an issue.
这个答案有帮助吗?
得分 2
2条评论:
It might be just worth the expense to replace it here's the needed part Mac Mini Bottom Cover (used) $11 USD
完成的
Thanks Dan. I had searched for these online but had not found one with reasonable postage to Australia. I have bought this one as both the price and postage were reasonable.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 196
