跳转到主内容
加入维修社区 - 创建账户
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Can not power on without external power
The controller will not switch on without being plugged into the xbox or on the charging Dock.
However once powered up like this I can remove external power source or dock and use wireless as normal, the home button also works in the xbox menu!
It just won't power on when wireless...
Battery is OK as I've swapped it already.
All board connections pads are clean and carbon free.
Any ideas guys n gals
I'm not scared of Pad/trace repairs confident soldering with iron or air, but this has me stumped.....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
My first thought would be the battery supply circuit as the cable seems to get it working.
This site gives quite a detailed overview of what goes where.
https://acidmods.com/forum/index.php?top...
这个答案有帮助吗?
得分 0
2条评论:
Thanks for that input brother!
I've only got a basic multimeter and really only done trace repairs and obvious component replacement.
Like I say this has me stumped but I will have another look...
I'm wondering if the standby voltage is supplied by the middle pin of the battery as that also displays 4.26v fully charged and decreases at the same voltage as the + pin upon discharge...
Or am I making things more complex in my mind lol
Kind regards Jace
完成的
@stonerjace middle pin is usually a temperature sensor thing in the battery. A wrong alignment of the pins can also cause a problem with starting on just battery power. Bad contact on the pins can also cause this.
完成的
添加一条评论
Hello, I am having the same issue, did you ever figure out what was causing the fault? I cant find anything anywhere on the Internet about it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
StonerJACE 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 46
总计 572
