跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2696 个问题 查看全部
phone turns on shows apple logo and then goes blank with backlight on
As the title said my iphone 6s turns on shows apple logo and then goes blank with backlight on, I don't normally use it I only when I want to take something from it but since this years it is just like that.
I have used the apple recovering PC software to do a restore and update but it fails when the phone shows apple logo and brings up error ( 2009 ) also when I try to use third party recovery software for update and restore it also fails please do anyone have a solution to this or know what might have caused it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Error code 2009 is a common error that can occur when you are trying to restore or update your iPhone using iTunes or Finder on a Mac. This error typically indicates a problem with the USB connection between your computer and your iPhone.
found on this apple forum.
https://discussions.apple.com/thread/255...
这个答案有帮助吗?
得分 0
7条评论:
If you feel comfortable with opening the phone you can get a spare charge port and connect that to try isolating the issue from the phone. It might be the chargeport or the cable.
iPhone 6s Lightning Connector and Headphone Jack
iPhone 6s Lightning 接口更换
完成的
I also tried using a Mac to do the restore but it gave me error unknown (21) maybe I try what you suggested about changing lighting port
完成的
@anthonyakuta I would at least start there as a cheaper way of eliminating points of failure if you don't have another charging and data cable available.
https://support.apple.com/en-us/108308#h...
This link says it is a hardware issue. Something that gives me a feeling it can only be 2 different points of failure. cable or port.
完成的
I have used a different cable like 3 different ports both USB A port and type c port, and I still get the same error when it reboots and just stops at apple logo and pop ups error (2009) or (21 on Mac )
完成的
@anthonyakuta Have you changed the port on the phone?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Anthony Akuta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 63
