跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
MacBook not charging the battery
I recently bought MacBook Pro A1706 with backlight issue, fixed it and factory reset it because the seller wanted me to, after installing the OS i noticed that the battery is not charging at all, in settings it has around 400 charging cycles so figured it shouldn't be bad, the seller also stated that it was not used for a long time, so my question is, is there any way to "jump start" the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I doubt "Jump Starting" is really an option here.
A battery which is not charging is more often a bad charger or the wrong USB-C cable. Then if you have a known working charger and cable the issue is within the logic boards charging logic.
I would get a USB-C power meter to measure the voltage from the charger feeding into the system what does it tell you? Do you see any power getting to the system?
这个答案有帮助吗?
得分 0
4条评论:
Charging voltage on the motherboard is 13V and something when charger is plugged (on the pins + and - that go on bms)
完成的
@dizzyrepair - You need to trace the path looking at the USB-C input point using a USB-C power meter like this one MakerHawk Type-C USB Meter Tester
完成的
Will check it out
完成的
Charging is fine, however I can't comprehend the BMS, on + and - terminals the voltage is 2.18V but when I desolder main + and - terminals from the BMS I get 11.47V from all the cells, seems like when the cells reach certain level of discharge the BMS components render the battery useless
完成的
添加一条评论
添加你的答案
Em4N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 68
