跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
Replacing the Audio Assembly
I have a customers 4th gen nano, there is no sound coming from the audio assembly, so naturally, i would replace it... but in the 4th gen nano it is soldered onto the board, i just want to know if anyone has ever successfully soldered a new one on, or fixed the old one, ie..replacing the pins inside it or whatnot. any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I think you will need an all-new board as the soldering is most likely surface mounted; making it incredibly difficult to solder.
这个答案有帮助吗?
得分 4
3条评论:
i received replacement parts from china, they have the setup done, but yes i am afraid to resolder or reglue... until i hear someone has done so otherwise
完成的
this is true, soldering a headphone jack on one of these is work for robots.
完成的
my ipod got the problem too,
i am looking for the parts in china,
just wanna know did u did it eventually??
完成的
添加一条评论
添加你的答案
Ptr702 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 2,406
