跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
Perfect working original screen stopped working after changing battery
So long story short I bought an iPhone XR 2nd hand that was in perfect condition apart from having low battery health. So I changed the battery and afterwards as I was putting the phone back together I kept checking to see if everything was working. It was. So I removed the screen one last time to apply the screen adhesive. Put the rest of the phone back together and did one last check before sealing it back up and to my surprise the screen stopped responding to touch. Iv had this exact same problem with 2 XRS now. One minute it’s working the next it just stops responding to touch. Any help or advice would be greatly appreciated. Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Goosed,
Did you disconnect the battery before re-connecting the new screen?
这个答案有帮助吗?
得分 0
1条评论:
Thanks for you reply, yes I always disconnect the battery first and reconnect it last.
完成的
添加一条评论
Odd. Have you been using the same supplier for the XR replacement screens?
I would usually say it might be a loose digitizer ribbon cable that hasn't been seated correctly, but since it has happened twice and it worked perfectly for a while, I would point a finger at the quality of the screens.
这个答案有帮助吗?
得分 0
2条评论:
Thank you for your reply. In this case I haven’t changed the screen at all. I’m putting the same original screen back on that I took off. The screens were working before I took them off and after when testing to make sure everything was working. Both times Iv had this happen it had been last thing after putting the metal brackets back and putting the last screws in and just like that the screen stops working. Iv done loads of XRs and iv only had this problem twice and I can’t for the life of me work out where I’m messing up.
完成的
I would then suspect that something is physically wrong with the connector. When the bracket is screwed down it might be pushing loose contacts apart. Perhaps it is a bit implausible, but I can't think of many other things that could cause this.
完成的
添加一条评论
添加你的答案
Goosed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 34
